How can I reset password?
How do I reset my password
Es esta una buena pregunta?
Hello Madison
Just like gatewaynomad said to make the instruction easier we will need to know what version of Windows your laptop is running.
Saying that resetting the Offline Windows password isn't to hard. Note that I said Offline password. that is because if you are using Windows 8 and above you can log in using your Microsoft Account password or any other online account password. If you have used an online account password to login, then you will need to reset your password using that online account reset password feature. If you let us know what online account you used I would be happy to provide you with a direct link.
If you used an offline password the you can follow the below instructions to reset it.
I hop this help.
Fue útil esta respuesta?
If you forgot a BIOS password, you can remove it by unplugging the battery for a while. If you forgot a Windows user password, it can be reset your password with Windows install CD. The last resort is format your hard drive and perform a clean install.
How do you format your hard drive and preform a clean install?
Melissa This would be done by reinstalling the OS from some form of installation media such as a recovery USB CD or DVD or a windows installation disk.
All I want to do is to change the password
Compaq presario cQ57
I would like to change my password on my compaQ laptop. Presario CQ57
On start : look on screen bottom may say F2 startup. On Bios. Look for password set up.
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 60
Todo El Tiempo: 10,796
7 comentarios
What version of Windows are you running?
Does it matter if you retain the data , or are you ok restoring it to factory settings?
- de gatewaynomad
I have windows 10.1
- de Christopher Ehlers
I need to retain my data
My laptop is Windows 8.1
- de Guillermo Torres Montalvo
I have a compact presario CQ5500F PC IT HAS LOCKED DUE TO SOMEONE RESETING MY PASSWORD HOW DO I GET PASSED THAT AND RESET MY PASSCODE
- de Mandochavez
Mostrar 2 comentarios más
