USB device is currently drawing too much power
The USB device is a camera and is drawing too much power it says that the hub will be deactivated
Es esta una buena pregunta?
Try plugging it directly into the Mac instead of a hub. If you are not using a hub, then the port you selected serves as one and you need to select another port. Disconnect your other USB devices and Firewire devices. Make sure your AC adapter is plugged it if using a Book. It helps us to know what king of Mac you are using.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,687
1 comentario
I am plugging into iPad with camera adapter
- de Thomas Stine
