Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Why is it not turning on
Not turning on I have tried over and over again
Es esta una buena pregunta?
Puntuación 1
1 comentario
do you get any lights or fan or hard drive sound
- de Compartir
Agregar un comentario
1 Respuesta
Solución Elegida
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 1,907
