Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La séptima generación de cámaras de GoPro, lanzada a finales de 2012. Capaz de grabar vídeo a 1080p30, sumergible hasta 197 pies (60 metros) y con Wi-Fi integrado.
Gopro hero 3 water damaged in salt water? help?
It may be too late but last afternoon the case cracked and some water got in, I noticed some salt forming from the water evaporating and also noticed it was getting pretty hot. I took out the battery and SD card but the SD card is broken. Now it will not turn on or charge. Again it might be too late but any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
3 comentarios:
I had the same issue , please help !
- de
My camera keeps saying no sd card and bippin every 3 seconds, so it doesn't record or connect to my phone.
I try to reset and did not work.
Any ideas anyone?
- de
Try swapping out SC Cards, different brands as well as Size of SD Card, Let say from a 64 to 32 etc. It has work for me, Believe or not they do come bad brand new
- de
Agregar un comentario
1 Respuesta
I’m not sure who to thank for the information on water damage for my GO PRO 3, cleaning all the internal parts with Isopropyl Alcohol worked, I was about to replace the mother board, and thank you for the tear down information of GoPro Hero 3 as well. THANK YOU ONCE AGAIN
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
jack land estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 1,247
