Saltar al contenido principal
El Sennheiser RS 120 es un sistema de auriculares inalámbricos RF con auriculares supraaurales abiertos. Este producto se puede identificar a través de su número de modelo, RS 120. El auricular es HDR 120 y el número de modelo del transmisor es TR 120. El Sennheiser RS 120 se lanzó al mercado en 2004. Ofrecen un sonido transparente y bien equilibrado con excelentes bajos. reproducción, lo que los convierte en una opción ideal tanto para uso de alta fidelidad como de TV. El RS 120 ofrece libertad de movimiento, diseño elegante y comodidad óptima a un precio asequible.
Preguntas 52 Ver todo
Frequently I get a very very loud static sound in my earphones
I have two headsets for the RS 120. One is fine. The other one sends a horrible loud burst of static every now and then and scares the !&&* out of me. Can anyone relate?
Can anyone advise how I could prevent this?
Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
4 Respuestas
OMG the same thing keeps happening to me
Fue útil esta respuesta?
Puntuación 0
Same problem here with two sets. Any answers?
Puntuación 0
I don't get a loud burst of static. My bursts are repetitive but low in volume.
I've found the following helps:
-- Moving the base station (where we hang our headset overnight) to where there's minimum obstruction between it and the headphones.
-- Turning off Surround Sound. That's done at the lower right of the base station. When SS is on, the base station has a yellow light. When the light is off, that helps. (Me, anyway.)
-- Try a different channel. That's done at the lower left of the base station. Might have to turn off the headphones to let it find the new channel. Or, on the left headphone, push the channel button. (Not 100% sure if this left headphone button tip actually works.)
Hope this helps someone. I love my Sennheisers.
Puntuación 0
I have the exact same issue. First set worked for years then commenced what you experienced. I threw them out. Just bought a new set rs120 II and 3rd time using, same thing. I'm returning them to store. I have a more expensive Sennheiser set, no issues over past 3 years
Puntuación 0
Añadir tu respuesta
Lynne Fletcher estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 41
Todo El Tiempo: 3,216
