Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2201 Ver todo
4s screen Black and white, fuzzy after change
I changed my cracked screen with a replacement from ebay I got for 20 bucks aud. Everything including touch works fine except for the display. This is what I get:
http://imgur.com/RL7flsu
Is this more likely a faulty lcd or something I've done?
The dimming you see in the picture is not a camera effect. Thats how it looks.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Did you take OFF the new screen protective sheet on the back of the LCD? If you installed the screen correctly and perfectly, then you need a new screen.
Fue útil esta respuesta?
Puntuación 0
This can be faulty lcd or you damaged when were replacing... check the connectors.
I will recommend you before replace the new lcd, test it please and connect with out removing old lcd.
Puntuación 0
Añadir tu respuesta
Simon Di Bella estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 93
