screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
Es esta una buena pregunta?
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
Fue útil esta respuesta?
very good answer and simple but very useful
This answer saved me.. thanks a lot
I dont have vr mode ,what to do,?
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
Where is vr mode located
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🥲
Ultimas 24 horas: 11
Ultimos 7 días: 59
Ultimos 30 días: 261
Todo El Tiempo: 23,572
8 comentarios
I have the same problem for a LG Stylo 3 that was stepped on.
- de April Smith
did u fix it i got the same problem and same phone
- de Jing Jing
- de Swetha Thomas
no my phone fell on the groud
- de zyasiamorgan5
Does this drain my battery?
- de Nancy Yengel
Mostrar 3 comentarios más
