Factory reset my dell
How do i factory reset my inspiron n5050
Es esta una buena pregunta?
you can follow in order to fix errors everything when you get errors in your pc you can aske google acually you can find the right ways that you can get fix
To restore your Windows 7 computer to factory settings
Back up important files and data. If you do not back up your files, you will lose them.
Turn off your computer.
Disconnect everything but the monitor, keyboard and mouse. This includes your:
scanner
printer
modem or network cables
mobile phone and tablet
USB flash drive or other external hard drive
If your laptop is docked, remove it from the docking station.
When the Dell logo appears on the screen, press F8 several times to open the Advanced Boot Options menu.
Note: If the Advanced Boot Options menu doesn't open, wait for the Windows login prompt. Then restart the computer and try again.
Use the Arrow keys to select Repair Your Computer and then press Enter.
On the System Recovery Options menu, select a keyboard layout and click Next.
On the next screen you can log in as a local user or the Administrator.
Note: Use the drop down menu to the right of User name: to select the local user or the Administrator account and enter the password for that account. If you have not set up a password on the local user account leave the password space empty and click OK.
Depending on your configuration, you may need to select Dell Factory Tools and then Dell Factory Image Restore.
Click Next to open the Confirm Data Deletion menu.
Select the Yes, reformat hard drive and restore system software to factory condition check box and click Next.
Note: The restore process begins and may take five or more minutes to complete. A message appears when the operating system and factory-installed applications have been restored to factory condition.
After the restore operation is complete, click Finish to restart the computer.
Restore any data or programs you want from back up files.
Fue útil esta respuesta?
does this work if i totally removed the stock OS????????????
But what if the local user option does not appear on the drop down menu?
If the pre installed os is Ubuntu, and when I did a factory reset within Ubuntu, it got crashed, so is there any method to factory reset the dell without booting the Ubuntu os...
scanner
printer
What if my blue function (fcn) key doesn't work?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 187,463
3 comentarios
how do i get back to factory settings
- de ken clarke
Last week I had a similar іѕѕuе, I couldn’t figure out how to factory reset my dell laptop.
Tried everything but nothing worked
Finally I managed tо do this after getting help from Dell Windows support
Follow the steps here: http://bit.ly/DellFactoryReset
It worked for me
- de Susan
To reset your laptop you have to go to settings go under updates and then go to recovery. Soon as you are on the recovery screen hit the reset this pc button. It will ask if you want to back up any files or just delete and reset whole laptop. Most likely you will need to reset whole laptop.
- de Debra Crumbley
