error 50 with iTunes restore
My iPhone 5c does not restore with iTunes and blocked with an error 50
Es esta una buena pregunta?
This is often caused by software issues on your computer. If you have access to a different computer running iTunes try using that one to do the restore. Otherwise, try uninstalling iTunes and re-installing, though if it's a different program running on your computer that's causing the problem this won't fix it.
Another cause of this issue is a hardware fault. Usually in that case it would be caused by a fault on the logic board, a very difficult repair.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,161
