Saltar al contenido principal
Lanzada en América del Norte en noviembre de 2006.
Preguntas 20 Ver todo
trying to connect my Wii remote
I'm trying to connect my Wii remote to the Wii aand it is not working!!!!! I have a rock candy controller can anyone help me!!!!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
I cant get it either and i have a rock candy remote to
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Rock candy is not a good choice for connection. Try to check for any problems with connection (ex. Bad battery, another connection is blocking the new one) and buy a regular remote.
Fue útil esta respuesta?
Puntuación 2
To get the rock candy wii remotes to work, you have to turn on your wii first, then take off the battery cover on the rock candy wii remote. Then, there is a little door-like thing on the wii console, where you put the discs in. Open up the little door and there should be a button. You can see on the bottom right corner there is also a red button. If you press and hold the 2 buttons, the rock candy wii remote should work. You can tell by looking at the bottom, where one of the little lights should be on. Hope this helps! :)
Puntuación 1
My rock candy does little flashes then stops
Puntuación 0
1 comentario:
Hey my rock candy flashes little then stops so I tried syncing it connecting and even putting batteries nothing works.
- de
Añadir tu respuesta
Valencia Jackson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 839
