Sensors not sensing TOUCH SCREEN
Samsung avant Touch Sensors not working after falling in water. Everthing else appears to work but touch screen.
Es esta una buena pregunta?
i'm not pro but as far as i know that's common that the Touch Sensor chip gets fried
if you sure that's the sensor you can replace it (Level 3 repair) did you remove all the resodue and other crap inside? if it's in pain in the ass package (soldered from under (so you need hot air)) then it will de really difficult to replace.
how is it connected? maybe the touch sensor is dead not the chip itself
you could wash your phone in pure water (destilled) or in alcohol (also pure)
water isn't conductive on it's own but in tap and mineral water there are some things solved
if you take water and put in it a lot NaCl (table salt) and put your phone in there for 3 seconds it will DIE
(or put it in mercury (conductive liquid))
maybe some more info?
also hit thanks button (or how is this called...) if i helped
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 569
hiii sir Iam trying to interface the touch sensor with Arduino Uno it's working but I don't know it was automatically turned on and off I don't know please anybody give some suggestions about touch sn sensors thank you.
http://bigbelectronics.in/product.php?pr...
- de subbu smart
