Why is my vacuum cleaner blowing instead of sucking?
I have a bissel 3510-W style 2 vacuum cleaner. It was working fine but after my son did something with it, it now blows instead of sucking and I have no idea why and of course, my son has no idea what he did (teenagers!) Thank you in advance!
Es esta una buena pregunta?
1 comentario
Generally, if a vacuum cleaner is blowing instead of sucking, it's likely due to a blockage in the suction pathway or a problem with the vacuum's motor. Here are some steps you can take to troubleshoot the issue:
Check the filters: A clogged filter can cause a vacuum cleaner to blow air instead of sucking it. Check the vacuum filters and clean or replace them as needed.
Check the hose and attachments: Check the hose and attachments for any blockages or obstructions. Clear any blockages you find.
Check the bag or canister: If your vacuum has a bag or canister, make sure it is not full or clogged. Empty or replace the bag/canister if needed.
Check the motor: If none of the above steps work, it's possible that the vacuum's motor is malfunctioning. In this case, you may need to take the vacuum to a repair shop or contact the manufacturer for assistance.
I hope this helps!
- de VacuumCleanersMag
