Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
Es esta una buena pregunta?
Puntuación 4
1 comentario
that fixed the problem. thanx.
- de
Agregar un comentario
6 Respuestas
Solución Elegida
Also, try visiting the troubleshooting page for more help.
Fue útil esta respuesta?
Puntuación 6
Respuesta Más Útil
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
Puntuación 18
12 comentarios:
Worked for me, i feel so stupid now
- de
Mine was not working either, Supid #2! Thanks!!!
- de
Wow! Thanks! *face palm*
- de
Add me to the dummy list! Thanks for the help
- de
Not working. Howwwee
- de
Mostrar 7 comentarios más
Try resetting the watch.
Puntuación 3
3 comentarios:
I reset it and it only vibrates on phone calls.
- de
I reset mine nothing, no vibrating at all. I'll try again.
- de
Though it works, feels over kill. Try the quiet mode
- de
No solution worked. No vibration at all even after hard reset
Puntuación 1
My pebble steel started to vibrate again, after android wear app was removed
Puntuación 0
2 comentarios:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
- de
Thanks. I m on the top of the dummy list!!
- de
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
Puntuación 0
Añadir tu respuesta
Orlandria Heggs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 16,072
