Saltar al contenido principal
Cámara de 7,1 megapíxeles de Canon, modelo SD750.
Preguntas 9 Ver todo
Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
Es esta una buena pregunta?
Puntuación 0
6 comentarios
No memory card in my camera
- de
Use the camera to reformat the card.
- de
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
- de
When it says no card what will you firmat bro
- de
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
- de
Mostrar 1 comentario más
Agregar un comentario
1 Respuesta
Solución Elegida
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
Did you get my last response?
- de
I guess not. All I got was that one
- de
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
- de
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
- de
Añadir tu respuesta
mesarey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 5,103
