top speaker not working what do I need to do
I can't hear any of my calls unless it on speaker why?
Es esta una buena pregunta?
I had this problem for months. Annoying and frustrating. Top speaker audio returned sporadically last week then stopped again. I had already checked for software conflicts and cleaned all the grills/ports with a toothbrush. Today I noticed one side of the phone looked slightly deformed. I held the phone by the corners and gently "twisted" so that the pressure was being exerted in the upper left corner (opposite the light and camera) and the top speaker came roaring back to life. Probably a loose contact but I was able to fix it without disassembly. Good luck.
Fue útil esta respuesta?
Dude holy $@$*, you're a *!&*^#% savior! I tried everything short of actually taking the physical phone apart and then I stumbled across this super old thread. I gave your suggestion a try, and sure enough the twist fixed the speaker contact issue. I was so happy when it "ROARED" to life! Even though this thread is old, I see that the person who started it never replied, and I wanted to let you know that you made one person really happy. Cheers.
oh my god this actually worked! i was stumbled why the heck he twisted his phone. but !&&* it worked! when i gently twisted the top part of the phone to the speaker side, i hear a pop sound then booomm music came out from the top speaker! you're freaking life saver man!
P/s: I actually just created this account just to reply to your comment.
Looks like there's something wrong with the earpiece. Check if it's getting stuck.
Hi, i have same problem, daughterboard has been replaced too.
maybe a firmware problem...
my guess is the connector i dont know whitch one of them but there are 2 small tape like
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 2,912
1 comentario
I have the same issue , i´ve already changed the earpiece ( tried putitng it one direction and other direction facing the contacts with the daugherboard) no results.
Tried the factory reset .still no results.
I´ll order some new speakers because the one that came from ebay didn´t have the coil part althogh i measured the resistence and there was a reding on 7 ish Ohms , any clue ? Could it be the dautherboard failure? because ive already changed the dautherboard once because of the power button.
- de Chromium chrome
