What is causing my wheels to get stuck?
The back right wheel on my stroller keeps getting stuck and the wheel wont turn.
Es esta una buena pregunta?
If your wheels are getting stuck, you should check to see if any debris is caught in them. If all the wheels seem clear, it may be that one or more wheels are damaged. If this is the case, try and identify which wheel or wheels are giving you trouble. You can then replace the damaged wheels using the Wheel Replacement Guide for specific instruction.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 5,359
