Saltar al contenido principal
The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
Phone Microphone only works in calls but nothing else
Recently, my phone's microphone stopped working which means it doesn't record sound in videos or audio recordings and also doesn't work in apps. The only exception is phone calls where it does work. Why is this? This has happened a long time ago before and it fixed itself so I left this issue for a while but it's been about a month or so and still nothing has fixed! I need my microphone to work asap because I need to record videos WITH audio for my school project! Need help!
Note: I have tried rebooting my phone
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario
My p8 lite does not ring or play sound /alarm / music and it is one week old
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
superelectrolizard ,
it is not software fault. your P8 having secondary mic (use for nice cancellation and voice and record sound with comparing. simply you can find it near the Headphone connector.
Here you can find teardown guide. check the mic contacts connected properly to logic board or replace the mic and see
as you mentioned on your question : not required to test primary mic as it works fine (bottom side mic)
Hope this answer will help you to understand the fault and fix it your self
Cheers!
Fue útil esta respuesta?
Puntuación 1
Buddy it seems like a software issue. Try factory reset but don't forget to take backup of your files. Mostly that should make it work!
Puntuación 0
Hi I have Huwaie p8 lite problem in my mobile is mic ni nothing working.during calling I used head phone.pls tell me how to resolve
Puntuación 0
Añadir tu respuesta
superelectrolizard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 6,976
