Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 23 de octubre de 2012. Procesador Core i5 o Core i7. Apple Fusion Drive.
Upgrade from i5 to i7 CPU
Hi,
I'm looking at purchasing a 2012 Mac Mini with an i5 processor. I have a PC at home that is not really used as I am a Mac user. The PC is pretty high spec - well it was 3 years ago. It's running an i7 processor and I was wandering if I could put it in the Mac?
Any help is appreciated.
Many thanks,
Steve
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
1 Respuesta
Solución Elegida
Unfortunately, Apple solders the CPU to the logic board, not allowing you to upgrade the processor. If you're still looking for a performance boost, though, you may want to consider adding in more RAM, perhaps up to 16 GB (it's a SODIMM DDR3 module, but some memory will not work; you may want to try Corsair Mac Memory), and installing an SSD.
Fue útil esta respuesta?
Puntuación 9
6 comentarios:
Many thanks for the througher reply Sejin.
- de
I have the Mac Mini with I7, 16Gb RAM and 2 SSD in Raid ... works like a charm if you don’t do video editing. You can add a 2.5/5gb ethernet adapter on USB3
- de
Why can't one unsolder the original processor and install the 7?
- de
@penitentman - Its not that simple! Take a look at this image Logic board with Heat sink lifted Not the chips under it are BGA with out the proper gear and skills you're more likely to kill your logic board and you still need to get the BGA version of the chip which is no longer made.
- de
Horseshit Dan. I realize not all have the skill but some do. Enough said. Never say never!
- de
Mostrar 1 comentario más
Añadir tu respuesta
stevetrueman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 72
Todo El Tiempo: 33,288
