Saltar al contenido principal
Repair guides, troubleshooting information, and service help for refrigerators manufactured by General Electric (GE).
Preguntas 240 Ver todo
What is proper temp setting for GE freezer/refrigerator?
I have a GE side by side refrigerator freezer (2004 yr model )
  • temp control is a picture of thermometer and a slide up or down
  • what is correct position
  • what position is colder
Es esta una buena pregunta?
Puntuación 1
1 comentario
hmmm, I don't know how to deal with freezers, but it seems that there is some problem with temperature control
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Usually up is for higher temperatures and down is for lower.
The optimal setting is dependent on the ambient temperature and how many times it is being opened during the day. Temperature fluctuations are also dependent on how full it is. The items in a refrigerator help retain the cold.
To ensure that your refrigerator is doing its job, it’s important to keep its temperature at 40 °F or below; the freezer should be at 0 °F. Since few refrigerator controls show actual temperatures, using an inexpensive freestanding appliance thermometer will allow you to monitor the temperature and adjust the setting of the refrigerator and/or freezer if necessary. Buy one for the fridge, one for the freezer, and check them often.
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
i set my frezzer to 0 and still had frost in the icebox why would this be happening?
- de
If there’s any gap in the area around the seal it will cause frost to build up in the freezer. That happens very easily when there is already some frost present
- de
Freezer 0* fresh food 36*. If your refrigerator temperature control is a dial, try turning it to the middle setting. After a couple days you can adjust it higher or Lower if need be. Allow 48 for the temp to adjust.
If that doesn't help, it could have several other issues. I'd need a model number to be of more help.
Puntuación 3
4 comentarios:
Hello Maria Marquez. Check the humidity control on crisper drawer. You want low humidity. Any temperature changes will take 24-48 hrs. If no change, include your model number. Thank you.
- de
I turned down both the refrigerator and freezer so that I can unplug it to clean the back. Plugged back in but the cold controls are not turning on. What did I do?
- de
I set the frizer temp on "0" deg Frenhit end get 28 deg Frenhit in the cooling compartment!
How can it be fixed?
- de
The freezer should be set for 0*F and the fresh food section at 36*F. I don’t know what model you have to determine more than that. There are several different ways a refrigerator regulates tempature. I’d need the model number
- de
Hello, I have GE refrigretator, but my vegestables,luttuce,onions,cucumber, and everything else freeze ,by the time im going to use it,i have to throw them away, what can i do to avoid this,?or whats the right temperature? thank you, Maria Marquez
Puntuación 1
1 comentario:
I have a Gth181bxcrww model and its making loud noise. What setting shoul i have freezer and refrigeratoron .its a dial model
- de
I have a fridge freezer fridge General Electric No: PCG23NHMHFBB
TG402277
Please help me regarding the temperature
It had three settings at the
1 Set is at -5
2 Custom coo is at 6
3 The other is at 36 set
Help regards Ann Ryan
Puntuación 1
1 comentario:
I need help with my GE refrigerator because I don’t know how to set up the temperature
- de
Añadir tu respuesta
nietta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 115
Ultimos 30 días: 474
Todo El Tiempo: 88,988
