charging paused, temperature battery too low
my samsung galaxy s4 gt i9500 won't charging, i check batt temperature is -25C , i already replace usb cable flex but still not work ,
sorry for my bad english
Es esta una buena pregunta?
hendri, since you " check batt temperature is -25C" then it is definitely to cold. Double check the -25C.;-) The usual causes for this error are issues with the battery connector, failed btemp line on the circuit board, bad battery, bad charging port flex. So if I would fix it I'd start with a new charger, then a new battery, then do some fault finding on your logic board.
Fue útil esta respuesta?
hendri ,
just clean the battery terminals
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,313
1 comentario
take out the battery and keep the phone under direct sun light for few minutes and try charging again
- de salikasumanapala
