Why is screen almost black?
iBook G3 Dual USB has a black screen that I can read with a flashlight. Is it the logic board? How to test?
Es esta una buena pregunta?
First, you are going to need to ID your Mac, so that I can point you to the correct part.
This is an inverter board issue. The inverter board is what steps up the voltage from your battery high enough to run your backlight. If your inverter board dies, there will be no backlight but the LCD will still manipulate its pixels, and you get the effect that you see.
Fue útil esta respuesta?
If it is the M6497, here is the inverter:
[producto vinculado inexistente o deshabilitado: IF150-043]
The LCD's available if it is not the inverter:
http://www.ifixit.com/Mac-Parts/iBook-G3...
And the guide to replace the inverter:
Either the inverter board or the backlight has failed. Try it with the inverter changed first, much cheaper than an LCD. You might find a reasonable priced complete display assy an eBay though.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 877
1 comentario
The model is M6497.
- de Michael
