Saltar al contenido principal
Revelado en 1999 como la computadora portatil de Apple para los consumidores.
Preguntas 232 Ver todo
What do I replace the original thermal materials with?
I am reinstalling my recently repaired logic board in my G3 900mhz iBook 14". The original thermal heat transfer materials on the heat sink were two preformed squares, the larger was a blue foam looking square, the other smaller one was gray and seemed to be a more solid version and consistency of thermal paste. Can I use the normal Arctic Silver paste for the installation or do I need to find the same type of original squares?
Thanks,
Randy
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Good question +
- de
Thank you, I'll give that a go.
Randy
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Arctic Silver Thermal Paste will work great om the heat sink in your laptop.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks. Do you have a recommendation for the thickness of the paste? The iFixit instructions say to spread a thin layer. The original materials were fairly thick, maybe up to 1/16th of an inch.
- de
My experience in the matter is that it's better to have a bit too much than a bit too little. You just really need to make sure you don't have any that comes out over the edges / spills out when you reapply the heat sink. 1/16 " sounds fine to me, I just like to make sure I can't see the processor any more through the thermal compound.
- de
Añadir tu respuesta
randy3833 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,238
