Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un teléfono con Windows conocido por sus capacidades de cámara. También conocido como Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
Phone not switching on
I was using my phone and then it got switched off due to no charge.
I kept it for charging and tried to switch on my phone but since then its not switched on.
It wont switch on due to some reason.Kindly help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Fazal, it is possible that it is just totally discharged. Try a new cable and a different charger. If that does not work, you may have a bad charging connector. In that case, try a new battery or one that has been charged with an external charger to at least get your phone to respond. Consider replacing the charging port. Here is a decent guide for that.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
That video is in no way helpful it doesn't show u how to remove the port I went through the steps a few minutes ago after releasing the 2 screws there is still another part of the flex cable which is behind the speaker and to remove the speaker u would have to break the backcase so my suggestion is to by the back case with the port
- de
Añadir tu respuesta
Fazal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 999
