Saltar al contenido principal
HP Envy TouchSmart 15, modelo 15t - j000. Año de lanzamiento 2013.
My battery life has reduced significantly.
My battery life percentage runs out more quickly than it used to. Why is that?
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
The battery after many charge and discharge cycles will lose it's ability to hold a charge. Extreme changes in temperature can also reduce battery life, as well as keeping it plugged in all the time. You should let the battery completely discharge once and a while to help it have a longer life. If the battery is unusable for your needs, you should replace it.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Giovanni Morales estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 382
