Installing iMac Intel 24" EMC 2134 and 2211 Dual Hard Drive
Because in my model the connection of the optical disk is ATA/IDE
Is it correct to assume that if I will install the ssd disk with this adapter Installing iMac Intel 24" EMC 2134 and 2211 Dual Hard Drive,
the disc will function less well and less fast than if I'll install the ssd disk on the place of the hard disk bay where the connection is the sata?
My plan was to install SSD as a primary disk with the operating system instead of the optical disk and 2T SSHD instead of the hard disk (on in the hard disk bay)!
Update (09/20/2015)
My English is not 100%, so please let me see if I understand you correctly:
1) So basically what you're saying is that anyway it is recommended that the Primary ssd/shhd will be installed instead of a hard disk -in it's bay,- rather than instead of the optical disk, because the IDE / ATA optical disk port is Significantly slower than the sata-II?
2) You suggest that I'm only going to install one disc and not two disks - because it is not economically for sach an old computer which is not clear how long it has to live?
{just For general information- Even if he dies. can׳t i just take it apart and buy an adapters to use them as external disks on usb2 - is it still will give my some of the ssd effect or it is useless?
by the way What was the point of this guy- Why do you think he installed two discs, including at the optical disk place/slow port? https://www.youtube.com/watch?v=-c6fmiFO... }
3) This disc will be a SHHD disc and not SSD!?
{If I'm going to install only one disk ( as you recommended), it is not be better to have 256ssd which I will install on it the operating system and heavy softwares for editing heavy the stills photos. And the rest of things like family photos and documents ..., I will keep on an external disk?}
4) about firmware updates,
i am running Yosemite 10.10.5 Do i need any firmware updates?
http://files.macit.co.il/374851b_forum_0...
http://files.macit.co.il/374851a_forum_0...
I hope I understood you correctly. And my questions are clear to you.
Thanks for your help and patience :-)
Es esta una buena pregunta?
