Saltar al contenido principal
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Preguntas 555 Ver todo
Steering gears loosen up
I own a Craftsman Lawn Tractor model 917.25022 with tight turn. The mower steering stops working in either direction. The small gear on the end of the steering shaft stops meshing with the flat gear underneath. A bolt loosens up that holds the flat gear. You can tighten the dickens out of it and it will steer for awhile and then it happens all over again. I had a contractor who does lawn mower service for Sears check it and he just tightened it up to get me by till the warranty expired. Does anyone know of a fix to stop this problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I do not have the exact same model but I had a similar problem with my Craftsman Lawn Tractor model 917.272220 --- it is a LT 1750 Limited Edition. I looked at your manual and it appears your tractor is similar to mine . Go to google and look up part "CRAFTSMAN HUSQVARNA STEERING SHAFT SUPPORT 160395 124035X 532160395 532124035" you will get some hits on ebay for the part. It is a nylon/plastic part that the steering shaft fits into. It gets wore and the part that the shaft fits into becomes oblong rather than the round shape it should be. The slop created allows the rack to no longer mesh with the pinion on the end of the steering shaft. I replaced this part and my steering tightened up and now I have full right and left steering that no longer "locks up". You can look on youtube for the video--- https://www.youtube.com/watch?v=Zvyft4aq... ---- this video does not do a good job of showing what is wrong but it does show the piece on the end of the shaft that needs to be replaced. The reason the gears in the video wore is because the small plastic piece on the end of the shaft is no longer round and allows the shaft to move and which in turn does not let the gears mesh properly. By the way, the plastic piece is held onto the shaft by a small bolt that you will need to remove by placing a socket with an extension into the plastic piece........ hope this helps.
Update (09/16/2015)
I opened the parts section on sears direct for your tractor...... sorry.... although the lawn tractors look similar the steering has a different design and is not similar to my model so the information I provided in my post will not work for you...... sorry again.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I have a craftsmen 26 horse and when I try to let out on the clutch and brake pedal I get a lots of noise it's sounds like the clutch but in again it's sounds like the rear end but I have a lot of play in the agreeing plat is that normal thanks
- de
Añadir tu respuesta
Paperman159 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 41
Ultimos 30 días: 205
Todo El Tiempo: 14,288
