Saltar al contenido principal
La cámara Polaroid One-Step 600 toma y revela sus propias fotografías. Cuenta con un flash automático, así como una lente especial para fotos de cerca.
Preguntas 41 Ver todo
Displaced spring in film release button?
A spring fell out from the left side of the film cartidge loading bay and I can figure out where it goes. It is a large u-shaped with a hook at each end. I am surmising it works to activate the release button to load film. If I had a schematic or exploded view of the camera, it might help to relocate it. Any suggestions?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Respuesta Más Útil
i think the best way is to use the pictures of the teardwon for that camera: CLICK
it's surely not a repair guide (but if you look on the right side, there are 3 step-by-step guides) - but it's shows the most of the inside parts of the camera
Fue útil esta respuesta?
Puntuación 2
Thanks, Marcus! I appreciate the help.
Puntuación 0
Hi
Did you ever resolve this issue. The same thing has happened to mine. I'm pretty sure it's the door latch spring.
Thanks
Stuart
Puntuación 0
Actually the U-shaped spring is the one that lets the door latch engage with the body. It is located at the right side of the Roller Assy looking from behind the camera. Observe the way it mounts on a functional camere, it´s tricky to describe in writing. The metal part it activates is visible on Step 9 of the dismantlich pictures.
Puntuación 0
Añadir tu respuesta
kevin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 4,990
