Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
What would cause coolant temperature gauge to stop working?
temperature coolant gauge was working fine, then just started working sometimes. now it's not working at all!when i have driven for a while i notice erratic shifting in the gears & some loss of power. i am having troyuble trying to figure out the the cause behind it. please help!!
Es esta una buena pregunta?
Puntuación 17
15 comentarios
hello everyone & thanks for your answers to my question . turns out the sending unit which is the sensor had went bad and needed to be replaced. so thanks again!!! :)
- de
I had to put in a new motor in my 99 dodge 1500 sport now the atl & the water temp gauge will not work at all I have not been able to drive my truck becouse of this can you help.
- de
I have a beautiful restored 1997 Dodge Dakota 5.2. My temp gauge is not reading hot but going the other direction. Normally it reads at 200 but is dropping down to almost the 130 mark. What does this mean? Help!
- de
hello, how to fix my ATOS engine temperater, when the watersystem not erro?
- de
Hi all, 2000 Mitsubishi galant 2ltr 5sp,Temp gauge-start it up drive about 2ks and T/gauge moves up to half way and stops there thanks for any help, Ray H
- de
Mostrar 10 comentarios más
Agregar un comentario
6 Respuestas
Solución Elegida
i can only guess - but the coolant temperature sensor failed very often on those models
since the audi is CAN-bus controlled, i would use the A/C or my CAN-bus reader to get the actual error codes. i didn't found a good source for the A/C trick in english - only german sources - here is a google translated page: CLICK
Fue útil esta respuesta?
Puntuación 8
It's a shot in the dark, but I would start by checking the thermostat first.
Puntuación 5
to verify if the sensor is what's causing the problem, disconnect the connecter from the coolant temp sensor, and jump a paper clip across the terminals. turn the vehicle on after doing this, and see if the gauge has moved in the dash at all. try the same thing with the connecter disconnected. if the gauge moves at all, then it is the sensor itself that has failed.
Puntuación 3
2 comentarios:
Trouble coolant sensor can stop engine
- de
On my clio when the gauge is at 4 the car struggles to start and flashes stop and when engine starts it goes off ! Could it b the coolant sensor? ?
- de
On the Audi the sensor is your problem
Puntuación 3
1 comentario:
Excellent answer. Please read the comment that the OP left, right below the question, on Aug 16, 2010. It was the sensor and did get fixed. Also check the Accepted answer from July 31,2010 where it was suggested that it is a bad sensor....;-)
- de
ECT (engine coolant temp sensor)
the ECT responds to change in coolant temp. by measuring the the coolant temp, the ecu knows the average temperature of the engine .
the ECT sensor is needed to controll many functions such as fuel injection, ingnition timing,variable valve timing, transmisions shifting ect.
Puntuación 2
1 comentario:
whats is the ECT
- de
I had the same problem happen today on my 92 Gmc sierra. It turns out the harness clip on the Coolant Temperature Switch snap off due to age I suppose. Anyway, I connected it and secured it until I can get a harness connect replacement (which for some reason is rather high in price for what it is). Cranked it up and took it down the road and the gauge works, it isn't loosing power when I come to a stop (it had stalled completely a couple of times earlier this morning), and I still have a little eratic shifting cause my tranny needs to be replaced. Ironic the same symptoms and problem here...wow. My radiator hose actually constricted a couple of times too. I constricted from the thermostat neck all the way to the radiator too.
Lee
Puntuación 1
Añadir tu respuesta
antonio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 42
Todo El Tiempo: 257,908
