Saltar al contenido principal
Portátiles fabricadas por Dynabook (anteriormente Toshiba). Desde entonces, Toshiba transfirió el 100% de la propiedad del negocio de computadoras portátiles a Sharp.
Preguntas 1278 Ver todo
Touchpad disabled every time I restart
hey guys, i own a toshiba satelite c660. some time back i installed virtual box, some few hours later, everything in the laptop broke down, the sound stop working, the vga was in its list resolution, the usb ports died, half of the keyboard failed, the touchpad stopped working, i tried and fixed all the problems, that is except the touchpad issue. when i log in, the touchpad is off, i enable it by fn + f9, but even if the laptop goes to sleep, the touchpad gets disabled again. It extends even when am installing other OS, i.e linux, the touchpad isnt working at all here and not even fn + f9 works. and i cant use an external mouse because the usb ports died completely, not even charging
please help
Es esta una buena pregunta?
Puntuación 3
1 comentario
Are you certain it is not a BIOS setting? Sometimes these settings are buried quite deep in the menus. I've often turned off the touchpads on laptops
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Hi Dennis,
If the problems persist in Linux, etc. then it is a BIOS issue.
Try this:
Power on the Toshiba.
Quickly press "F2" to access the boot screen.
If you miss the boot screen and the computer continues to start Windows, shut down and try again.
Press "F9" to load the BIOS setup defaults on the laptop .
I would also reflash the BIOS as well.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Ha! Just fixed it with a random thought. Tried so many things too!!
The previous owner (it's a work notebook) had jammed something into one of the USB ports and broken it. The plastic/insulating center piece had been broken off and two of the pins were very bent and making contact with the upper surface, I grabbed some tweezers and straightened them out.
When I switched it back on....Boom, a mouse pointer without having to hit Fn+F9 prior to the login screen.
I suspect the contacts made by the bent pins was somehow fooling the OS into thinking there was a USB mouse connected and so shutting off the trackpad by default. Only think I can think it is.
Woo hoo (hope it is a similar fix for you )
Puntuación 3
3 comentarios:
awesome! exactly the same.
- de
Amazing! Thank you. I was trying to get Windows 10 working on the same laptop and this was the final hurdle, I was just about ready to give up before finding your post :)
- de
Not an answer (sorry), but I am having the same issue with the C660. Was occurring on a Win7 OS, installed Win 10 fresh and it persisted. Updated BIOS (although it was ancient), still occurring.
With a different OS and on a formatted partition at that, seems to be a hardware/BIOS issue. Doubt Toshiba will address this on such an old machine though. Seems to be a post-login necessity from now on
Fn+F9 for life
- de
Try doing a master restore before going into the os, sounds like all the drivers got corrupted
Puntuación 0
2 comentarios:
ill like loose all my stuff, aint it better to just reinstall.
but my problem is why is the touchpad not working at all even when running livecds of linux distros
- de
It sounds like a driver issue, im not familiar with linux so I cant say.
- de
Añadir tu respuesta
Dennis Mwasela estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 24
Todo El Tiempo: 3,847
