Calibration
News
Forums
Today's Posts
Log In
Register
Home / Dodge Caravan
Blend Door Calibration
#1
Terry Donlan's AvatarTerry Donlan , 11-24-2010 12:00 PM
I have a 2005 Grand Caravan that has the 3 zone Heat/AC unit. Every season I have to have my Blend Doors recalibrated because it won't allow me to redirect where the air is blowing. Does anyone know the procedure to recalibrate the blend doors? I have to go to the dealer twice a year to have this done and they charge me $100 each time. I'm sure it's easy to do, I just need to know how?
The New 2017 Corolla
Explore Models, Options & MPG. Get the New Premium With Corolla. Continue at www.toyota.com/Corolla
#2
Tizzy1's AvatarTizzy1 , 11-24-2010 02:22 PM
A/C-HEATER CONTROL CALIBRATION
The A/C-heater control module must be recalibrated each time an actuator motor or the A/C-heater control is replaced. If the vehicle is so equipped, the calibration procedure also includes rear HVAC positions for each actuator motor.
Turn the ignition switch to the On position.
If equipped with the manual temperature control (MTC) system, press and hold the Rear Wipe/Wash and Recirculation buttons for at least five seconds. If equipped with the automatic temperature control (ATC) systen, simultaneously press and hold the Power and Recirculation buttons on the A/C-heater control for at least five seconds. The MTC A/C-heater control Rear Wipe/Wash button light emitting diode (LED) and Recirculation button LED, or the ATC A/C-heater control Delay and Recirculation graphics will begin to flash when the calibration procedure has begun.
The calibration procedure should take less than two minutes to complete for the manual A/C-heater control, and less than twenty seconds for the ATC A/C-heater control. When the LEDs or graphics stop flashing, the calibration procedure is complete.
If the LEDs or graphics continue to flash beyond the two minute (manual) or twenty second (ATC) calibration time, it indicates that the A/C-heater control has detected a failure and a Diagnostic Trouble Code (DTC) has been set. Refer to Body Diagnostic Procedures to perform further diagnosis. The LEDs or graphics will continue to flash even after the ignition switch is cycled Off and On, until a successful calibration is completed or until the vehicle has been driven about 13 kilometers (8 miles).
2 comentarios
I also have a 2007 Dodge caravan And so far these last few years if I turn the fan all the way off then when I turn it back on the fan won't come back on as if there is a vent door stuck this stopping the blowing ,but I say that because when I hit a bump going down the road it comes back on ..But this last time it just stuck.what can I do???
- de christine green
its nothign to do with the vetn door. the wire plug on the motor is loose and losing connection. hitting bumps loosens the wire plug. sometimes they get hot and start melting the plastic on the wire plug and make plastic burn smell. which could cause a fire in some cases.
- de RANDY S
