home iPhone6 home button replacement will id still work
if i change my home button on my iphone will the id finger senor still work with new home button
Es esta una buena pregunta?
No, Touch ID will die immediately and if you try to restore/upgrade iOS, the phone dies altogether.
Fue útil esta respuesta?
Hi,
Try a hard reset ,
Where you press the on/off switch and home button .
It has worked for me every time I have had the issue.
Hope it helps.
Thanks
If you replace it with a home button that has a touch sensor in it, then yes. Why are you changing the home button, is it broken?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 103
