ABS light always on, tachometer don't work, mercedes 280ce 1984
I have a Mercedes 280ce 1984
Automatic
And the ABS light its on, and the tachometer stop working.
Es esta una buena pregunta?
Automatic
Hi, I'd suggest looking at the OVP relay. Some 1984 model year W123's were equipped with this and your symptoms make me thing it could be the culprit. You can see the guide on checking and replace the fuse, and if needed replacing the relay, here:
Mercedes W123 Over-voltage Protection Relay and Fuse Replacement
If it is not your OVP relay or the fuse on the relay you'll need to do some more diagnosis and share some more info, I think. You haven't given us too much else to go on.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 322
