HAVE NO TEMP CONTROL IN MY 2001 Ford f150
How can I get temp control in 2001 F 150
Es esta una buena pregunta?
Heat control Not Working No Heat Just Cold
Fue útil esta respuesta?
Same make and model? what have you checked? Did you at least check the antifreeze level?
Antifreeze is what I was going to suggest also. my car wouldn’t warm up or blow heat unless I was punching the gas. Otherwise it was just blowing all cold. Checked my radiator fluid and it was almost gone. Found the leak and fixed it. But that might be something to check if you already haven’t
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 1,143
No hot, no cold? Fan motor works? Selector switch working? what have you checked
- de oldturkey03
Did you solve your problem? My temperature is also not working. This may sound silly, but were your backup lights also not working? iamretired
- de Tom Richards
I had no back-up lights. The problem was the TR sensor. It did fail and caused a dead short, which blew the number 5 fuse in the fuse panel under the dash. Replaced the TR sensor, changed the blown fuse, and now I have back-up lights. AND as an added bonus the blend door in the climate control (heater) system is working again. Good stuff. Thanks to old turkey 03 - 2 problems solved.
- de Tom Richards
I know this sounds silly but does it have it? It may just have fans
- de MaxAwesomeness GB (Max)
Does what have what?
- de Cameron
Mostrar 3 comentarios más
