control locked light on nothing works
the control locked light is on and i can not shut it off as a result nothing works what's wrong? tom h.
Es esta una buena pregunta?
TOM H, try the normal procedure which is to hold down the "end of cycle signal" (drain/spin)button for 3 to 5 seconds. The only other thing I could see is that the control interface has failed and has a stuck or shortened keypad. Also, in the event it should not work, unplug your washer for ab out 15minutes to see if it will reset.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 897
