What is the best way to descale the machine
machine keeps telling to descale after it has been descaled
Es esta una buena pregunta?
Guías de reparación y desmontaje para la cafetera Breville BKC600XL
Roy Perham, use 50/50 water/vinegar mix per instructions. After proper descaling pull the plug for at least 15 minutes to clear the message
Instructions state 100 percent vinegar up to the “Max” line for the BKC600XL model and a purge to replace the water with the vinegar followed by letting the machine sit turned on for a minimum of 4 hours.
There is no need to unplug the machine for 15 minutes as the machine detects the need for descaling. If the descale message persists, you’ll need to run another cycle of vinegar through the machine.
You can find precise instructions on descaling your machine on page 28 of your manual and the purge process on page 18.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 987
