Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Preguntas 274 Ver todo
Install single 2.5" SSD?
How can I install a single SSD in the main Hard Drive slot without the fans running at full speed? It's a Samsung 850 Evo, so no other connectors for a thernal sensor cable.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
You need to use this cable: OWC In-line Digital Thermal Sensor for iMac 2011 HD or SSD Upgrade. It makes no difference who's SSD you use they all require it.
Here's some background info: SMC issues
Fue útil esta respuesta?
Calificación 3
Comentarios:
Even though this is a 2010 model? Doesn't Yosemit support TRIM?
por
The first cut of it didn't, the current version gives you a way to enable it. You don't need TRIM enabler software. It's a simple command line you type in a terminal window and it's done! Latest OS X update allows you to enable TRIM for third-party SSDs.
por
Añadir tu respuesta
Vijay estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 9
Todo El Tiempo: 570
