will not turn on after having a power outage
my workforce will not power up after a power outage.
Es esta una buena pregunta?
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
Fue útil esta respuesta?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 5,088
1 comentario
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
- de Tyler Momberger
