How to added transmission oil
how to added transmission oil
Es esta una buena pregunta?
boris, not an easy thing to do. Going to be tough without a lift or a pit. There is a fill plug on the back of the transmission. Remove the plug and put a finger in the hole. If it doesn't come out with fluid on it, it's low. To refill, fill it up in the hole until it comes out. Remember to use CVT fluid only
Fue útil esta respuesta?
It should be up to the bottom of the hole somewhere around 100 degrees Fahrenheit.
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 87
Todo El Tiempo: 15,826
