Saltar al contenido principal
A highly stylized new generation of Volkswagen Beetle, called the New Beetle, produced from 1997 to 2011.
Preguntas 46 Ver todo
Hi Beam headlights won't stay on, only flash?
Hi Everyone,
I have a VW New Beetle 2002 and replaced with new the Indicator/High Beam Stalk Switch as the old one was faulty and didn't lock in (when pushed back) for high beam light and hi beam lights didn't work.
Now high beam lights only flash when switch pulled forward but nothing happens when pushed back for hi-beam lights to stay permanently on?
Is it a relay or something else?
Any help would be appreciated.
Thanks,
Steve
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
put in a new bulb for the head light in vw bug 2010. daytime running light on passenger side works but not head light, high or low. can you help me please?
- de
Hi Steve did you ever find a solution? Got the same issue here
- de
Agregar un comentario
1 Respuesta
I would check the fuse if that's OK go for the relay swop it for another one if it works you then know, a lot of the relays can be swopped over !
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Wogboy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 3,246
