Saltar al contenido principal
Nuestro grupo ha creado una guía de reparación para la cámara digital Canon SX40HS para que la usen las personas que desean desarmar o reparar su propia cámara. La guía contendrá una página de solución de problemas, imágenes y 3 guías de reparación para problemas comunes con este modelo en particular.
How can I replace the SD card reader? (Memory card error)
My camera was taking great pictures & I had just uploaded my photos & replaced the card in the camera when I had a message on my screen saying "Memory card error". I have tried other cards, looking to see if the metal/gold colored wire is in place to connect with the card, etc....I have also used canned air to blow-out any dust, dirt, sand, etc....from the card slot. Nothing has worked...Other ideas other than replacing the card reader slot ??
I LIKE the photos I got from this camera & would like to try & repair it ! Please help ??!! Thanks ~~
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
The answer is no. The SD Card Assembly is physically attached to the Main Board. You would have to
replace the Main Board. The cost of that repair is probably more than just buying a used SX40.
Like you said, you swapped out other cards, checked for connectivity issues, used air so it does sound
like it could be the board.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
leezalanson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 715
