Saltar al contenido principal
Lanzado en octubre de 2008 / 2.4, 2.53, 2.66, 2.8 o 2.93 GHz Procesador Core 2 Duo
Preguntas 376 Ver todo
Are there glass removal instructions for the MBP 15" Unibody?
Hi,
are you able to tell me how i have to proceed to remove the glass from the screen in order to preplace it?
Sommetimes , someone tells that you have to warm up a little bit the border of the glass then pull the glass in the corner with a Suction and a small plastic tool by putting it between the glass and the screan , and sometimes we you don't have to warm glass first .
Thank you for your help.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
We have that guide for the 13" MacBook Pro Unibody here (steps 15-22). The glass removal is the same procedure as your machine. Once the glass is off, however, there may be a different orientation (especially with screw locations) for further disassembly.
Good luck!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
brice06 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,421
