Saltar al contenido principal
My power button is stuck and is at a slight angle.
Do I need to open the unit for adjustment, cleaning, or something else?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
It's probably getting caught on the rim of the hole it's inserted into. See if you can gently move it away from the side it's caught under.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
all the buttons seem to be "off center" as well. Guess I get to open this thing up now.. Thank You!!!
- de
I am having a similar issue...my power button seems to be stuck. It won't click. It's not crooked. I've replaced the power supply. That didn't help. Can you please suggest something I can try to fix this? I bought a new button, should I go ahead and replace it? Or is it something simpler maybe? Thanks in anticipation of your answer. Kirstie :)
Puntuación 0
Añadir tu respuesta
Greasieb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 120
