agitator making noise going back and forth?Whats wrong
Agitator makes noise going back and forth during wash cycle
Es esta una buena pregunta?
Ronals Sassano, that could be caused by a bad tub bearing. It could be that the bearing has worn out and that's what's creating the noise. The bearing is a part of the outer tub assembly. The bearing is punched into the outer tub at the factory. It is also possible that it is the transmission or the motor coupling as well as worn agitator dogs, Since we can not hear what you hear, you may want to consider posting an audio/video file on youtube or similar.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 99
