Why does my Pontiac keep loosing power and shifting hard
will run fine then starts acting up.if i turn it off and restart it runs fine for a while looses power
Es esta una buena pregunta?
Check your trans fluid level. This is done when the motor is running and warmed up,check the smell of the oil If it smells burnt there could be more problems.Check the color it should be pink (Red) if its browning change it. hope this helps
Fue útil esta respuesta?
Are you a mechanic I see you posting on a lot of these car questions?
I worked for a lot of years as a heavy truck mechanic as well as light auto but now I'm working in robotic repair and maintenance
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 108
