How do I re-attach the bezel to the rear panel?
Theres a gap between the bezel and the rear panel, how do I fix this ?
thank you
David
Es esta una buena pregunta?
thank you
David
the only way to get this done, is to disassemble the phone, fix it and reassemble it.
use the rear panel guide - the bezel is pretty much the last part you can remove on the iphone - so getting to it means, removing everything.
good luck with that
Fue útil esta respuesta?
If your back panel is all jacked-up you may want to replace it.
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 2,232
