Saltar al contenido principal
Guías de reparación e información de desmontaje para portátiles fabricados por ASUS.
Preguntas 2518 Ver todo
How to replace Asus Laptop N550LF plastic hinge cover?
Hi,
I have Asus N550LF laptop which has the plastic hinge cover broken.
Ordered replacement OEM plastic cover, but unable to get it placed correctly.
Could you please provide instructions on how to replace the hinge cover?
Many Thanks in advance for helping me.
Regards,
Gokul
Attached the replacement part and place to fix it
replacement part
place to fix it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario:
Hi,
Could someone please help in fixing this issue?
- de
Agregar un comentario
1 Respuesta
Hi,
a premise:
the correct procedure to remove the hinge cover without breaking the little teeth is to carefully slide it to the left (so the teeth get free/unlocked) and then pull it away.
So, to install a new hinge cover, you have to first align it to the left and push it in, then slide it to the right.
Hope it helps :-).
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
should the laptop be opened or closed when replacing? Also, which portion is considered the top?
- de
The laptop must be opened.
Top is the display, bottom is the keyboard :-).
- de
I have a555l asus ..my hinge cover has broken ..so can it be replace at service center ..laptop is in warranty
- de
Añadir tu respuesta
Gokulnath estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 8,981
