Gas sensor gauge reading faulty on 2000-2005 Cadillac DeVille?
do I need the full fuel sender with pump?
Es esta una buena pregunta?
Hi, If your fuel sensor is bad you will need a new fuel pump as the sensor is part of the pump assembly. I am including a link to a forum discussion on the matter with a possible solution to the pump reading problem and if you go all the way down a possible easy access to the pump assembly. Good luck Ralph
Fue útil esta respuesta?
++ nice link
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 10,087
