Songs on laptop not showing on iPod
All my songs on the laptop are seen to be synchronised to my ipod but the songs are not transferred to ipod to play
Es esta una buena pregunta?
ok - since majesty and richard held me at gunpoint - i write my answer again.
first of all, i never use any automatic function in itunes.
i simply drag and drop my stuff on the ipod
open itunes and connect the ipod (it must be set to manual "whatever this in an english itunes version is called")
open a finder/explorer window and navigate to your music folder.
then simply select the files you want - then click and move the files to the itunes window and simply drop them on the ipod
Fue útil esta respuesta?
+ I haven't done this but may start
Tried it but same result,appears on file explorer but not on iPod.
Are you sure that the songs are checked off on itunes? If the songs arent checked off they'll play in iTunes but will not be synced to your iPod. Check on iTunes and make sure that the songs in question are checked off next to the title. I have found that sometimes while clicking a song to play it, I would inadvertently uncheck it by mistake.
+ good point
Check to see if there are exclamation points next to the songs in iTunes. How full is your iPod?
Beat me to it. LOL
+ you earned it both, i was simply to slow with my answer
hey, I just upticked your answer, it was another solution
Yeah Markus, your suggestion was worth leaving up there, it can possibly help if our solutions don't help.
+ to both
Ok there is a couple different reasons why this could be. First, if the songs are unchecked it is normally set to just sync checked songs and playlists. So checking the songs may resolve the issue. Secondly if it is just purchased content that is not syncing you may need to authorize your mac through itunes to play that media and sync it to the ipod. You can authorize the computer by going to the store menu in itunes than to authorize computer in that menu.
Xen
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 8,422
