Saltar al contenido principal
Pantalla de 7.9 pulgadas / Modelo A1432 / Disponible en blanco o negro / Anunciado el 23 de octubre de 2012/16, 32 o 64 GB de capacidad
Preguntas 220 Ver todo
How to fix my display not working correctly?
Hi,
Changing the glass of the ipad mini, when I finished the display won't work correctly. I just displays randoms lines and the bottom of the screen is all black.
I tried cleaning the connectors and pluging it again, but no success. Any ideas ?
here's what is looks like
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
Solución Elegida
It appears that the LCD is damaged. It is hard not to damage the LCD or digitizer when trying to do a glass only repair. Applying to much pressure, or using the incorrect tools can easily damage the LCD. Your display in the photo signals a cracked or damaged LCD. You will need a new display assembly (digitizer + LCD) to fix your device.
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
Why is a new digitizer necessary? I have the same issue here, but if the vertical lines signify a damaged LCD, wouldn't that be the only thing to replace? Just trying to save $70 if I don't have to spend it.
- de
Yes you would only need an LCD if the digitizer is undamaged.
- de
Thank you, appreciate the assist!
- de
It looks like you damaged the LCD while replacing the digitizer. What you will need to do is buy a new LCD for the ipad and carefully take the ipad apart again and replacing the lcd with the new one. The glass+digitizer you purchased is still fine and as long as you remove it without damage you can use it again when you install the new lcd.
Puntuación 1
how to repair my ipad mini,i cannot open my itunes only disable never working.
Puntuación 0
LCD is cracked.involuntarily you have applied too much pressure and LCD is broken. you should replace it.
Puntuación 0
Añadir tu respuesta
marcalexandreleger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 790
