Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1347 con procesador Core 2 Duo de 2.4 o 2.66 GHz.
Using DDR3 PC3-10600 rather than DDR3 PC3-8500
Hi all,
Has anyone tried putting in the larger DDR3 PC3-10600 ram into the mac mini mid 2010 rather than the recommended DDR3 PC3-8500.
Es esta una buena pregunta?
Puntuación 1
1 comentario
Here's a good reference: DDR3 SDRAM
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Sure the faster (newer) modules will work. But you don't gain anything as the systems memory access speed is fixed.
I would just buy the cheaper modules. Also remember the systems limit is 16 GB.
Before you do anything make sure your firmware is upto date. Follow this Apple T/N: EFI and SMC firmware updates for Intel-based Macs.
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
I have run into some machines where the faster RAM DDR3 PC3-10600 would not work in a DDR3 PC3-8500 native machine. I know it should but it didn't. This was last seen in a 2010 15" MBP.
Puntuación 4
3 comentarios:
Thanks Mayer, I'll consider this before I buy.
I wonder if Apple have a software hack to stop it...
- de
Same here, put 10600s into MM 2010, three beeps only. Will not run.
- de
@chrishees - Check the PCH logic as the older series won't support the newer SO-DIMM's.
- de
Añadir tu respuesta
Nim Anderson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 11,010
